Hi guys, i cannot see the battery icon in the taskbar, i've been into the control panel and tried switiching it on and off but still no luck? Any help and advice would be great, as its really annoying!
Hi dhi16on,
Try logging off and then back on again, this usually restores missing icons in the system tray.
hey, Rich sorry for not replying back but thanks it worked great!
You're welcome dhi16on
It's a shame that Microsoft haven't found a permanent solution to this problem...
