I can't connect my wireless. On the VAIO Smart Network window which I access by clicking on the green icon on the taskbar, the slider is switched to Off for the Wireless LAN. When I try and slide it to On I get an error message saying 'Enable the Device'.
If I click on the settings button of this window and choose Wireless LAN the Mode is missing. The drop down is greyed out so I can't add anything in here anyway.
I have tried everything!
I can connect to internet using ethernet cable but just not on wireless.
I'd would be so greatful for some help.
Hi OLSYWOLSY,
Are you sure that the wireless switch is turned on? If so try reinstalling the wireless driver.
If you need further assistance then let us know your Vaio model number.
Rich
