Hi I have just brought a replacement battery I charged it for 24hrs and it still flashed saying charging . Now I have no power,charging,hard drive led & no display is this a problem with the battery ,or the computer ? The three green lights on the key pad just below the screen would come on then go out. But now when I plug in the charger all I can hear is a fan running on the top right hand side of the key pad can anybody help or shed some light on what the problem is ?
Hi martjones,
Rich
