I have recently had to format my hard drive, which I done so using the resotre disks that were provided when I purchased my laptop, howevery now I am unable to play any DVD's on my laptop, everytime that I put a dvd in it says "a compatible DVD decoder is not installed on your computer" I have tried to download decoders but nothing seems to work.
The make of my DVD drive is...
Matishita UJDA730 DVD/CDRW
does anyone know where I would be able to find a decoder that will allow me to play dvds, if anyone could help it would be greatly appreciated.
Thanks
on your revovery disks should be a program that will play dvd's
i have intervideo.
explore the disks and see what you find.
I answer is here :
Just install a pack with
"a compatible DVD decoder on your computer"
Hi
Put in your applications disk and install WinDVD.
Thanks for all ur help, ive got it sorted now.
