Hi Need your advice
Just purchased a new tx2xp/bI'm having problems with dvd drive - it wont burn dvd's , it doesn't recognise some and some it doesnt complete the burning process.
Dvd reading, cd reading and writing are fine
If you haven't tried yet - could i get you to try burning a dvd and see if it works. If it does - can you recommend any brands that do work with your tx
Thanks
