Hi All,
Can anyone tell me how I go about getting the WWAN service enabled?
Thanks
Sam
Anyone??
I am no expert
, but if you are talking about Wireless Lan and assuming you have a router, then you slide the Switch over at front edge of your laptop - a light will show it is on and after it's a case of point to Start, Connect to, Show all Connections and if Wireless Network Connection is disabled then click and Enable. Click on it again and View all wireless Connections, Under Network Tasks - Refresh Network List, select your Router and the rest is self explained of what you will need e.g. WEP Key! If I understood what you asked then this is one direction you can take. You most probs have a Green Switcher Utility in your system tray which switches between Wireless & Bluetooth. All general information is on "My Documentation"
section of desktop. Good Luck!
thecloud.net offers WWAN, but you need to be near their hotspots.
Is this what you wanted to know?
Thank Kee-Lo, I should have realised!
You never know I might be wrong....
Could you clarify what you wanted Sam?
Hi All,
Thanks for the replies so far and the link
Basically I just wanted to know how I would go about setting up WWAN on my laptop.
WLAN isn't a problem, got it connected to my wireless router at home straightaway. :smileygrin:
All I really know about WWAN is that it is wireless internet on the go, but I am unsure if the C1Z has the hardware built in to connect to the services offered, or if I need to purchase new hardware for it.
I assumed it was built in due to the WWAN light next to the WLAN light, but from what I've read you need a sim card, and I cant see anywhere to install one on the laptop itself.
Any advice gratefully received
Sam
Sam,
TheCloud needs you to be in one of their hotspots, but if you wanted this sort of thing you would need a Vodafone 3G card - or even T-Mobile's Web n Walk 3G card. These are both PCMCIA.
It aint cheap.
Ah OK I understand now, so the cloud is like distributed WLAN.
I think I'll leave it then, I dont wanna get tied into a pricey 3G Contract or get any new hardware.
Thanks Kee-lo :smileygrin:
Hi Sam
No problem, I totally agree, it's very expensive. I know you can get fixed prices now but they're £30. Nowadays you can get an NTL 10mbit connection for this price!
