Can anyone recommend a good place to buy a 64mb memory upgrade for a Vaio C1XD? Cruicial.com and Kingston don't appear to stock the memory anymore and although I've found a handful of companies selling the memory it tends to be very expensive (sometimes over £100). I'm in the UK but anywhere in the world considered if the postage rates are good. Thanks, Tony.
Wow Tony - Thats very expensive for 64Mb
That's because it's very specialist William, not many people use that RAM anymore, which is a bummer.
Have a look at Offtek - they do it at just under £50 postage is free.
HTH
AFAIK all of the C1X series notebooks use the same memory. It's probably best if you telephone Offtek to confirm that it's OK with your particular model though.
I've bought memory from them before and they were helpful.
Yeah they look good value
