Anyone knows how much would an LCD re[placement screen cost for a Vaio A517S?
Hi jungletrekker,
unfortunately it would probably cost more to replace the screen than your vaio is actually worth..:smileysad:
Maybe worth contacting one of Sony's authorised repairers for a price then decide if you want to go ahead or maybe purchase a newer vaio.
To find contact details for Sony Vaio support use the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch
Then Click on the Out of Warranty tab to locate the nearest location.
