my cam looks too dark and i cant seem to find the settings for it?
probably really easy to find too sorry!!!
laptop pcg -7f1m
karen:smileygrin:
while your camera is running go to c:\program files\sony\VAIO camera utility. from this folder double click on VCUServe and then a box should appear. click on advanced settings and then you can adjust camera settings.
well i get as far as the sony folder but there is no camera utility folder from here!
karen
are you sure you specified the correct vaio model as i cannot find any drivers or support for the model you quoted, in vaio-link.
