Dear all,
I have a FE 31M laptop with winxp sp3 media center edition. I believe that my dvd writer is broken. Because whenever I try to burn a dvd, after a couple of minutes an unexpected error occurs. I tried burning at different speeds and with different disks and different files. According to the nero log, this error is caused by the matshita dvd writer.
I've had such a problem before, back then I sent the laptop to sony, and they have fixed the problem. Now I do not have any warranty left any more, and I think sony would charge me way too much for replacing the dvd writer. So I'd like to change it myself. Is this possible, and is there any information on how to do this?
By the way, I think the lifetime of this dvd unit in my fe31m is very, very short. I would have expected a lifetime of at least four years from a laptop that has cost me something like 1500 euros. Now, the dvd unit is broken 2 times in not even 2 years! Maybe it's time for sony to start using good quality units in their laptops, or to drop the price.
Thanks in advance for the help!
Hi Thalamus,
Under device manager I have two (?) devices listed under dvd/cd rom stations;
- HWJ D6F0L234D2F SCSI CdRom Device
- Matshita DVD-RAM UJ850S
A little note here:
The first device was not listed under device manager until I got the laptop back. I found that a little bit strange but I didn't bother investigating because everything worked. I expected a new dvd unit then, but I guess they have just fixed the old one.
The pioneer driver update shouldn't be of any help here I think, and the other update does have 850 in it's filename but that one is from late 2006. I bought the laptop in 2007, so I do not think it will do any good?
Hi Pat_D,
before going down the replacement route have you tried using a different make of DVD, something like Verbatim as Matshita drives can be a bit temperamental at times..
Have you tried removing both the HWJ D6F0L234D2F SCSI CdRom Device and Matshita DVD-RAM UJ850S from device manager and restating you vaio and allowing your CD/DVD drive to install again.?
Have you installed any other CD/DVD burning utilities lately.?
Hi Thalamus,
I haven't removed the devices from device managers list. I will do that now. The dvd's I tried to burn were from Verbatim. It's strange, because I've already burnt like 8 dvd's from the same manufacturer and it all worked fine.
Tomorrow I will try to burn a dvd from another manufacturer, I need to go and buy the dvd's first ;).
I will keep you posted
I've tried burning on dvd's from other manufacturers. Now more errors arise. I tried the other things mentioned in this thread. Unfortunately no succes. I think it would be best to purchase and install a new dvd unit...
Anyone who knows how to do that?
Thanks,
Hi Pat_D,
Just two screws ..................
Hi Blencogo,
Thanks :). I will be changing it tomorrow then :).
Thanks for the help all!
Hi Blencogo,
Sometimes the faceplate just slides off and can be repaced on a new drive. This is usually easier if you pick one with the same make. Sometimes it is held on with small screws.
Sometimes it requires a bit of DIY - if held by rivets. I'm afraid they are all different - but there is usually a solution.
Good Luck.
