I have reinstalled my VGN FZ21Z notebook, and when PC starts up the screen is much too bright. Pressing Fn & F5 reduces brightness but I can't remember what I need to change in the taskbar to keep the setting.
When I initially purchased the PC this March I know someone here advised me what to do. Unfortunately I can't find the post.
Would be really grateful for any help.
Thank you
Hi blue10,
Right click on the power icon in your system tray and select power options.
The power options window should appear.
Under Vaio Optimised, you should have Change Plan Settings, click on the words Change Plan Settings
A Change settings for the plan: Vaio Optimised should appear.
You should see two columns Battery or AC power,to reduce the brightness move the Adjust brightness slider to the left under either battery or AC power.
Then click Save changes.
Hopefully when you restart your Vaio the brightness should be at your required level..
Hello Thalamus
Thank you once again for your kind reply. Have now adjusted and brightness is reduced.
Best wishes
You're welcome blue10..
