I have put a new h/drive and reinstalled windows vista, all seems ok BUT....when the laptop boots, just before the load screen appears, to get it to boot any further I have to press enter, or one of the other keys!
This happen just as the microsoft corporation and the load icon appears...
If anyone could help I could use the advise - model no is VGN-NS30E
Thank you in advance
Andy..
let me also say thank you for the help I recieved the other day, I felt a real div but now know where to look for the model no
Message was edited by: adw1705
Hi Andy,
This may be a longshot but try resetting the BIOS to defaults - tap F2 at boot to enter BIOS settings.
Rich
Thanks for that, but still the same I'm afraid, bit of a mystery that one
Cheers for your help tho
Andy..
Hi Andy,
Mystery indeed!
Is there any disk activity (flashing LED) prior to having to press a key to proceed and is there any message?
It may be that a system file is missing or currupt and pressing a key aborts the search. If so a Startup Repair may help.
http://www.sony.co.uk/support/en/topics/solutions/29758
Rich
Led is flashing, no messages tho, have done 2 clean installations now and both have done the same thing!
Got a mind of its own I think
Hmmmmmmmmmmm.........
Hi Andy,
Does it boot successfully in Safe Mode? Tap F8 at boot for this option.
Rich
yes indeed,I did try that one..
In that case it would seem that at normal startup there is either a driver missing or currupt or a service that for some reason is unable to start.
Troubleshooting can be time consuming but I suggest you start by trying a selective startup.
Rich
Ok, will see what I can do, thanks for your time and advice
Andy
Good luck and let us know how you get on.
Rich
