it does not:smileysad:
so, I would have no chance?
is it possible to boot my VAIO SR21K from my USB-Stick?
My BIOS-Version is PhoenixBIOS R0208D1/RD208D1
if it is possible, how do I have to prepare the USB-Stick?
If it allows you to boot from a USB memory stick in the BIOS, then yes you can.
Preparing it just means upzipping all the files on the bootdisk, and having nothing else on the disk.
ok, but how/where do I see, if BIOS would allow booting from USB-Sticks???
What version of BIOS do I have to have installed???
Press F2 when Sony shows up on the screen.
The BIOS you have should be able to do it.
