Hi there,
does anybody know if it's possible to boot from an USB memory stick (or the SONY memory stick) to DOS or UNIX?
I can't find any options in the Phoenix BIOS for any USB device,
not even USB-Zip, USB-Floppy or USB-HDD.
Are there any other options I could use to make it work?
Or is there an update for the BIOS which could help?
I'd appreciate any kind of help.
Thx in advance
I do not believe it is possible. The only USB device it will boot from is a genuine Sony USB Floppy Drive. A non Sony will nort work.
Check out the accessory finder to ensure you get the right model.
William
