dr
how to reinstall bluetooth drive and function in my pc vpceb1m1e/wi
thank you
I have looked at the specifications for your model and I cannot see any mention of Bluetooth being fitted to your model.
http://support.vaio.sony.eu/computing/vaio/specifications/index.aspx?m=VPCEB1M1E_WI&l=en_GB
Check the specification sheet that came with your Vaio to make sure - but I think you will need to buy a Bluetooth USB dongle to be able to use bluetooth.
http://www.mobilefun.co.uk/atomic-pico-bluetooth-dongle-p21481.htm
Unfortunately it will take up a USB port.
