Sony Vaio PCG-TR5MP
Bluetooth; It works great until I turn off laptop then I have to remove Bluetooth Port drivers, re-boot and re-install drivers before BlueSpace NE works again.
What Happens; Bluetooth works Ok, it finds devices and connects. When I disconnect or shut down and re start I switch on `wireless¿, Device Switch opens and I tick box `Enable Bluetooth Devices¿. Bluetooth light on front panel comes on the connect sound is heard, but when I open BlueSpace NE, the message in the dialogue box reads `¿Bluetooth power is off. Please turn it on. Status also reads `¿Bluetooth power is off. In the Device Switch icon on the task bar `¿B¿¿ is present.
In effect Device Switch has turned on Bluetooth, but BlueSpace NE does not connect. To remedy this I have to remove Bluetooth port drivers from hardware list, re-boot and re-install. All works fine until I disconnect BT or turn off laptop again.
Wireless LAN works OK.
Can you please advice?
