I have a new fe11m and i am using the wireless connection but i cannot get the bluetooth radio power to turn on.
If i try and use the setting program it just say that bluetooth in not enabled but i cannot find away to enable it.
Can someone help me out here.
Thanks
If you mouse over the right side of the taskbar, you should have a tooltip which states " Selected wireless function...etc" Double click the icon and you should be able to enable bluetooth from there
Hahahah I had the same problem as you did on my FE11S after 1 hour i found it. You can get there in two ways:
1: The icons on the right bottom of your screen you can see a GREEN one with the text: LAN in it. Right click on it and choose show main dialog. A screen opens where you can choose to enable Bluetooth.
2: my computer->controll panel-->vaio controll center-->go to folder network connections-->open wireless switch settings. And you'll get the option to enable bluetooth
Good luck:smileywink:
thanks guys all working fine now:smileyhappy:
