[:">] hi got a pcg-grt896sp, discovered i haven't got bluetooth or infrared which would people recommend? please help, i read the other posts but still can't decide any ideas?
Bluetooth is a lot more reliable and flexible than IR. IR is not supported on most new devices.
Yeah bluetooth is better and it has a better range (10m)
Thats a very open ended question. What do you need to do with either?
IR is very simple and therefore user friendly. Bluetooth can be tricky to setup but once its going you can potentially achieve much more.
thanks for all responding, but its mad thatyou buy an expenisive laptop and it doesn't even have infrared or bluetooth - i just assumed it would!!!!!
Hi hongie.
I'm about to buy the GRT996 and i wonder if you could tell me your opinion about your laptop:
Have you faced any problems?
Is it easy-to-use? I'm worried about its weight.
Does P4 2.8 GHz provide enough power?
Finally, does wireless lan works well and the lappy has 1x512 MB or 2x256?? This is very important to me because i want to have 1 GB memory.,
Thank you in advance!!
Please, answer if you can!!!
ASSUME makes an ASS of U and ME...Samuel. L.Jackson
Haha he's such a good actor.
