Guys,
Need some help......
I cannot connect my Nokia 8910i mobile phone to my Sony Vaio via bluetooth. I've tried all the settings on the laptop but it still cannot find the phone?
Any ideas??
Are you using Windows Bluetooth Support or BlueSpace NE?
Sorry for sounding dumb but I'm not sure???!! How do I find out?
In the system tray you'll have a Bleuspace icon.
try turning the firewall off...."norton internet security".... also if your nokia has ability to set up a a bluetooth serial cable then u will need to create and outgoing port
