I've got the VGN-S3XP and used to have the S2XP. For some reason I can't get my blue tooth to function on my new laptop to connect to my phone. The light on the laptop for blue tooth will not turn on and I'm not sure if I need a function key to get it to activate. I've gone to Control Panel and tried to add my phone under Bluetooth Devices but it won't detect it even when I set detection to be on with my new Motorola V3 phone.
Perhaps I'm missing out on something here? Can anyone help?
Turn on your wireless switch
The switch wireless device dialog box appear
Select bluetooth option and ok
that will turn on your bluetooth
look in the start up bar tray where the small icons are and u shoud see a green square saying LAN, double click that and the rest is self explanatory, use the windows bluetooth file transfer to send files as u wish
