I am a proud owner of a new Vaio computer. The model is VPCEB1E0E/T. I discovered that it has no pre installed bluetooth driver. How can install an internal bluetooth device? I dont like those external stuffs.
Hi kiasira,
welcome to Club VAIO..
I don't think it will be very easy find and install a compatible internal blue tooth card and fitting an internal BT card will probably void your vaio's warranty as well.
You could however buy a mini usb blue tooth dongle something like the Iogear GBU421 or the Kensington 33902eu
If you buy a mini USB blue tooth dongle make sure it is Windows 7 compatible..
