I am trying to Sync my phone with my notebook but the Nokia Phone software cannot find my bluetooth connection.
Which software needs to be on my PC to make it work? (i have the Toshiba Bluetooth stack installed etc).
I may have removed some of the Sony software that is needed.
Hope you can help
Chris
Could someone please post a link with an up-to-date version of the Toshiba Bluetooth Stack?
Thanks
You may wish to download, latest version of Nokia, PC Suite:
http://www.nokia.co.uk/A4222001
Just select your phone model and it will guide you through the installation and connection of you phone from begining to end!
It's a start, but if not:
Do not forget to Turn on Discovery in Bluetooth Devices - Options Tab including the additional settings also on this tab that you will see! :smileygrin:
