I am not establishing an Active Sync connection between Z1XMP and HP Ipaq 4150 via Bluetooth. I successfully paired the devices but Blue Space NE is not allowing the connection. When I run active sync icon on Ipaq the process is starting and disconnecting immediately. It was very easy with HP notebook which it was using a different BT software.
Any help much appreciate, regards.
Hi there,
bad news: no way to sync Z1 with iPaq. After VAIO needed to apply the new Bluetooth-stack from Microsoft after Service Pack 1 was distibuted, it is no longer possible to sync iPaqs with Bluespace anymore. There is no work-around, no fix or patch.
I am sorry for the bad news!
Hi there,
Hi there,
Thanks for your respond. No communication between two hi-tech machineries is very sad. IMO Sony has to investigate and fix the problem.
Regards,
Sorry for that, my man...
You have to let go of your Pocket PC, I believe!
