hi there!
i have some trouble with the BlueSpace NE Software and my Nokia 7650.
BlueSpace (Version 3.4.00.13230) on my VGN-A117S isn't able to detect any services on the 7650.
the device authorisation (pairing) works fine, but no services are found. i can send files from my 7650 to my vaio by the other direction doesn't work.
any solutions for this problem?
my nokia is fine, it works perfect with my desktop computer. (acer bt-500 bluetooth adapter & widdcomm software)
thanks
simon
p.s.: (search function would be great!)
Simon, did you install Service Pack 2 (SP2) for Windows XP on your notebook? Both BlueSpace NE and SP2 seem to clash with each other.
no, sp2 is not installed.
