Hello people from club vaio,
From a long time didn't use to have problems with theblue screen but since I started playing with my notebook vaio VGN-FZ485U it happens, my computer is locked with the blue screen and a countdown appears in the left bottom of the screen, somethig related with dumping the memory...
Here goes the problem report:
Product
Windows
Problem
Shut down unexpectedly
Date
04/09/2009 09:51
Status
More information available
Problem signature
Problem Event Name: BlueScreen
OS Version: 6.0.6002.2.2.0.256.1
Locale ID: 1046
Files that help describe the problem (some files may no longer be available)
Mini090409-01.dmp
sysdata.xml
Version.txt
Extra information about the problem
BCCode: a
BCP1: 37DF0018
BCP2: 0000001B
BCP3: 00000000
BCP4: 81C4D014
OS Version: 6_0_6002
Service Pack: 2_0
Product: 256_1
Server information: 1886887b-8272-464c-8971-d359f7d12797
Does anyone knows why? If it's necessary I'll put the refered files here or any other files that may be needed.
Thank you for the attention!
Normally with a BSOD the timer is for the pc to make the files up and then reboot. But the best way that I've found is to disable the automatic restart on startup and recovery, this way you can write all the error codes and then google them to find out what is wrong with the pc.
Have you tried booting into safe mode and see if that is stable without getting the BSOD ??
If it works then it could be something thats loading up in Normal mode, if this is the case I would use msconfig to disable all the startup options and try each one to see which would give me the BSOD.
Hi Fadusp.
I've have had this problem for half a year (since hour one, day one) and Sony have not been able to make their Vaio notebooks work. "Blue screen crashes" 4-40 timas a day and Sony says/claims that this is their normal standard! Get away from your Vaio, get your money back and buy another p.c. that actually works, because Sony will not be able to help you. I have a mail from Sony that tells me that they don't know what to do with the "blue screen crashes". You can look up on the "blue screen crash" rapport under faults reports. Sony does not know what to do with these codes, desperate the fact that they define the problem!
I am after half a year a proud owner of a Macbook Pro and this p.c. are lighters ahead of Vaio! May Sony Vaio burn in hell!
Kind regards from
Pihl
Hi again.
I have been writing some on this subject too:
http://club.vaio.sony.dk/clubvaio/dk/da/forum/viewthread?thread=62896
Check it!
Kind regards from
Pihl
Product
Windows
Problem
Date
04/09/2009 09:51
Status
Problem signature
Locale ID: 1046
Mini090409-01.dmp
sysdata.xml
Version.txt
BCCode: a
BCP1: 37DF0018
BCP2: 0000001B
BCP3: 00000000
BCP4: 81C4D014
Service Pack: 2_0
Product: 256_1
