fault in file: tifmsony.sys
PAGE_FAULT_IN_NONPAGED_AREA
STOP: 0x00000050 (0xBA3F1000, 0x00000000, 0xF86144E0, 0x00000000
Happens when i try and use a device plugged into a usb drive. I've been able to use my usb ports in the past, only just happening now after sony fixed my cd rom drive!?!?
i honestly dont know what to do. i've tried a full system recovery, i've tried uninstalling all usb drives and reinstalling them, i've uninstalled all my new hardware and installed again........i'm completely lost.
One other question if anyone can help me....i knwo how to enter bios but it says to disable shadowing or caching in memory options, as far as i can see there is no memory option!!!! i cant even see if usb is abled in bios coz i dont know where to look!!!
Thanks for any help you may be able to give me
thanks from the idiot at wits end!!!
Hi there
I'm afraid I can't offer any practical advice other than point you to this site which may help.
ok, thanks, i'll try anything at the moment.
