my computer will not read my blu ray disc. but it will read normal dvd.
it says i need an update, but with one ?
i have a intervideo windvd BD. ( A vaio)
if you could help it would be great
I have a VGN-FZ38M. My Bd Dvd doesn't detect blu ray discs though it detects the dvd ones.
Hi lvapinto0
welcome to Questions & Answers..:smileyhappy:
Have you installed the latest WinDVD BD Update - 8.8.0.154 that's available for your model.?
There is also a firmware update available for the BD-Combo Drive Firmware UJ-120B. However you'll need check in Device Manager that this firmware update is compatible with the drive installed in your VAIO because they can be supplied with various optical disk drives..:smileywink:
