I'm looking to purchase a new Vaio C-Series and have three choices of disc player.
The description is a little confusing though
Option 1 - straight forward DVD re-writer
Option 3 - straight forward Blu-ray re-writer
Now my question, Option 2 - Blu-ray/DVD player
Somewhere in all the garb I found it saying there is was drive that will play blu-rays AND WRITE cd/dvds
Can someone please confirm if this is that drive
Many thanks
Scott
Option 3 is the one that will enable you to burn data on bluray discs
You can double check this by looking at the cost of option 3 - it should be more expensive than the other two
Hope this helps
Yes and no
Option 3 is another £140 over the standard DVD re-writer - all singing, all dancing
but will option 2 only read dvds or can it also write?
No it wont
The spec doesnt say "RW", it only says BD - R/RE/RO
The "RW" (read write) in the spec relates to the DVD drive and not the bluray drive
And this is further confirmed by the higher price so Option 3 is definitely the one you require
