hi ,I have Vaio VGN-AR61M,I have problem with Optical: Blu-ray Disc Combo Drive BD ROM/DVD+-RW/+- R DL/RAM Drive,region-europe ,it isn't read blu-ray discs,why ? what can I do?
Hi bartekgr,
First of all are you trying to play it via InterVideo WindDVD BD for VAIO? If you are check that the settings are on europe: Load the WinDVD up, right click the background, click setup, then go to region.
If this doesn't work go to your vaio models' page on VAIO support and drivers and updates. Her make sure you have the latest updates and firmware
Hope this helps, Mark.
