my vaio vpcea1s1e/l screen gets blank in mid of working and only solution for me is to remove battery plz help me
Have you downloaded and installed all new updates for your Vaio from Vaio Update? I see there is a graphics driver update.
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?m=VPCEA1S1E_L&l=en_GB
Have you installed any new software or drivers that may be causing the problem?
Are you sure all your software is 64-bit compatible?
