hi i recently bought a vaio fe11h.i dont know wat i did.. but just now in startup the windows xp runs fine but i cant see the screen.i just see the mouse pointer on the screen could someone please help me on this aspect.sorry one more question does anyone has sonyfe11h recovery cd??
your help will be much appreciated.thanks
mannie
Have you tried to boot in Safe mode (press F8 several times @ the startup screen) and select safe mode.
If all works fine there do a system restore to a time when all was still ok.
If all that fails you can recover using the recovery partition, but all the howto is clearly explained in the bundled manuals...
