Hello,
I want to run a 160GB Harddisk in my PCV-RX202. To do so I need a bios upgrade, so that it detects the harddisk. Where can I find bios upgrades fpr my machine?
Thanks and regards,
Chris
http://www.vaio-link.com
Have you gone to VAIO-User and entered your serial #?
Once you have, go to downloads and go to your OS. You should see the BIOS at the bottom of the list
Well, not very much. If you know the US equivilent (which I don't, sorry) you could search US support for the BIOS in question.
I was looking for a BIOS update too, but for other reasons. If Sony don't have it, you can't get it. The motherboards are bespoke and so the makers don't support them, which is very annoying.
