Hi there.
I have a Sony vaio vgn/c1s notebook. I bought it more than a year ago, it worked fine till now, but yesterday I saw that the battery doesn't show up in the os. I formated it, tried many things but it's not working. the battery worked fine till yesterday. Can somebody help me ???
Hi I have a Sony AR3!S and have had it for over a year and having identical problems as you.
Not sure why? How long does a battery last?
Me too. My husband reckons it's because i left it on standby/sleep mode alot and used it alot on A/C? But he's a Luddite. My system's a couple of years old, Sony want me to buy a new battery at nigh on £160.00. Pah! Unimpressed.
S
Hi Futky & all,
welcome to Club VAIO..
I suspect the batteries need replacing..
A simple way to check if this is a battery or possible hardware problem is to take your Vaio to a local stockist and ask if you can try another battery in your Vaio..
thanks... I'll give it a try, but buying a new battery I saw as the last choice.. anyway thanks a lot!!
You're welcome..
