Can anyone help please.....
I am having a problem with my battery. When I turn my computer on I get a message saying....
The installed battery may not be properly connected to the computer or may not be compatible with the computer.
Now it was fine yesterday and I haven't done anything to the battery prior to getting this message.
I have followed the recommendations - Turned comp off, removed battery, cleaned connections and reinserted battery but the problem persists.
The computer is ok is I remove the battery and just work of the mains supply.
My comp is a VAIO notebook VGN-FS115B, model number PCG-791M.
I would be most grateful for any help.
Thanks Sally
Hi, i know you posted this in 2006, but i just wondered if you ever sorted this problem out, as i have the same problem, and i have tried everything to sort it out. Just like you did. Please could you let me know. Many thanks, Millie.
