Hi everyone,
I have bought a non genuine battery for my vaio (as you cannot get the sony model anymore). Now, I had an error message saying that it wasn't compatible with Vaio. I went to the MSConfig and removed the tick for this and this removed the error message. I have also tried to reinstall the Microsoft Drivers for batteries which hasn't helped either.
So, has anyone had the same problem and what did you do to get it sorted? ![:slight_smile: :slight_smile:](/html/@3191CA7235A406D833094BA2DD1CF2FF/images/smilies/011.png)
Thanks,
Kat
