vaio VPCEB4X0E it work on AC or on Battery (charged in second laptop) but it will not turn on if battery and AC are plugged together and if turned on on battery orange light is flashing plus if you plug charger it still work on battery, if battery removed works fine on AC. Thanks Tom - I suspect something died inside - can I find any diagnostic tool?
