Does anyone know how to fully charge the battery on the vaio, mine gets to 80 % and stops. I have the power plan set to Balanced. Does this make any difference ? The laptop is only 5 months old and Ive always had it plugged into the mains and not used the battery ?
Hi tinytan,
This is probably due to the battery care function being enabled.
Depending on your model you can access this setting either via Vaio Control Center > Power Management > Battery Charge Settings, or with newer models I believe it is accessed via the Assist button.
Rich
