deleted by user
Message was edited by: jackiebrown85
I'm getting a bit worried about your Vaio!
You should find the Battery Care Function in: -
Start -> Control Panel -> VAIO Control Center -> Power Management -> Battery -> Advanced Settings.
I can't find full English specifications for your model.
I think you will have to phone Vaio Support for a definitive answer.
deleted by user
deleted by user
