Oh dear - my second ever post, and it's because I think there is something wrong!:smileysad:
I've left work and set up my own company - hence the purchase of my VGN-A197VP. I cut a cd containing all my work stuff before I left my old company, but when I try and copy some of the files onto my hard disk I get a 'data error Cyclic Redundancy Check'.
At first I thought it was a problem with my CD, but I tried it my Dell Optiplex desktop - and it reads all the files perfectly!
Anyone else had a problem with their cd/DVD drive? Anyone got any suggestions?
Darren
Hi there,
I worked on the same model but haven't had that problem that on that VAIO. On other manufacturers, though - so the other way around.
1. Check for scratches
2. gently clean the lens of the CD-drive
3. or try e.g. this software CD-check
Good luck
Thanks for the help. I tried the CD-Check program and it detailed all the CRC errors on the disk.
I ran the same program on the Dell and no errors whatsoever were found!
Anyone explain that???:smileyconfused:
