IS IT NORMAL TO VAIO THAT HAS LAST THAN ONE YEAR START TO STOP WITHOUT ANY CLEAR REASON, AND HAVE A LOT OF BAD BLOCKS ???
sORRY I WROTE WRONG!!!
LESS THAN ONE YEAR!
Hi cecilia.morina,
Welcome to Club Vaio,
If your vaio is less than a year old and you have a faulty hard drive, then I would suggest you open a warranty case via Vaio-Link..
Indication of hard drive failure indeed.
Bad blocks can happen at any time. This is usually caused by a knock during operation
Once you get bad sectors on a Hard Drive,the Drive will start failing.
