I am looking to confirm if the following Sony Vaio config has a backlit keyboard SOny SVE 1512M1EW. If not, is it possible to upgrade with a replacement backlit keyboard ?
I think there is no BackLit keyboard in SVE-1512M1EW: Sony Vaio SVE1512M1E Technical Specifications
Have you get in contact with Sony Support to ask, if it’s possible install one? Sony UK Support Contacts
Some options e accessories are available when ordering a “customize” PC, but, it’s too difficult (or impossible) find and/or install them after.
| Non mi aspetto nulla. Non temo nulla. Sono libero. - I hope for nothing. I fear nothing. I am free. (N.K.) |
