does anyone know how to install for a dutchspeaking user the french azerty can be arranged ?
@ tab and { are still reversed:smileysad:
You may be able to do this in CONTROL PANEL.
click on Regional and language.
you may find that if you change your region, it will change the keyboard layout for you. Not so sure if it would change the language though !!!
Thanks Steve I' ll try .
hi thanks for reply
azerty
mr b say,s thanks for reply
You can buy stickers to replace the keys so they can see the real key
