Hi people,
Does anyone know if there is any other type of audio player that can be used on Clie SJ33? I have a lot of tracks that are MP3Pro and they won't play on it and it would take forever to convert them all to normal MP3 :smileyrolling_eyes: also is there a player tht would allow you to play files lower than 98Kb/s?
DangerousDaveDeath
I don't think there is any player for mp3pro. It is not a well supported format. If you check out www.cliesource.com then you will get more information. Their Clie forum is very active.
OK thanks for the info dude
DangerousDaveDeath
Dude ?
Dude
Some other players are:
Aeroplayer
MMplayer
