I have a PCG-GRV616S notebook and i'm having problems with the ati mobility 9000 graphics card After having installed the latest graphic card driver downloaded from Sony Vaio's website, I began to have problem with playing games. The laptop hangs, I have re-installed 'Windows' with the recovery cd supplied with the laptop, but this does not seem to solve the problem.
I have again re-installed the latest driver in you website, but the problem still persists.
the only way the notebook works is if i remove the drivers then it willl not hang at all but if i try to ..i would like to know if any there is someone out there that has the same problem and if so if you have found a solution........:smileycry:
did that too and the same happens it hangs
Ok well since you don't seem to have a lot to lose try following the instructions at this link:
Patjes Mod
It does basically the same thing as Omega drivers, only a bit differently.
Check all the silly things like the fan being on max, and it being properly cooled so it's not something like an overheating problem.
well i have given a try to this one to but it does not work again i get the same problem when i try to play games it hangs
