Hi Guys,
I am trying to rebuild my Vaio VPCEE2E1E laptop. So while it is switched off I press the Assist button, the computer starts up and you see the Vaio screen then it goes black, you then see a flicker and it goes black again and just sits there with the power on.
How do I get it to work?
Message was edited by: -Cass-
Edited for personal details
Hi jbrines and welcome.
When you say that you are trying to rebuild your Vaio, what do you mean exactly? If you give a bit of background it may make it easier for someone to help.
It sounds like Vaio Care is not working or not installed. Can you still open Windows normally? If yes, try opening Vaio Care manually.
If you are trying to Recover the Vaio back to factory settings, try the following: -
1. Turn on your computer and press the F10 key several times before the VAIO logo disappears.
If the Edit Boot Options window is displayed, press the Enter key.
2. Select Start recovery wizard.
To perform the custom recovery, select Tools instead of Start recovery wizard
and click Start advanced recovery wizard.
3. Follow the on-screen instructions.
You can download the Troubleshooting and Recovery Guide for your model from here: -
ftp://ftp.vaio-link.com/pub/manuals/RecoTS/2010Q2_TRG_EN.pdf
Hi everybody.
I had same problem, when I turn off my lap top then press assist button, I couldn't see the VAIO Care (Rescue Mode).
How can I do that?
