Hello,
I love the crisp resolution of my AR51SU on 1920 X 1200 but as said by others it makes me get headaches and neckache because text is too small to read.
I calculated on a site the proper DPI settings on this resolution for my 17 inch screen and set it to 133.2 %.
This is definitifly better but on internet explorer fonts are still small. When I change the font setting in IE to large of larger fonts are too big for buttons and everything gets out of proportion..
Any other suggestions ? Is there an other resolution i can use ?
thank you,
Olivier
You can always lower the resolution, down to 800x600 (try 1024*768 for example, which is a pretty standard resolution), but on LCD displays the result is not as nice as when you work at the native resolution (1920*1200). Some characters may suffer "scales" effects, pictures may look a bit blurry. Try & see...
