I've had a problem with my WinDVD BD which was so bad that I decided to uninstall and reinstall from the recovery discs. However, when I user the VAIO Revovery Centre, it is not listed on the programs that can be re-installed. I can find the WinDVD folder on my recovery disc, but cannot install from there. So, no more Blu-ray films. Cab anyone tell me how I can re-install the original version o that I can upgrade to the latest version? Thanks in advance.
Hi zodski,
welcome to Club Vaio..
I have sent you a Private Message, use the following link to View your messages: Private Messages
hi,
I would also like to know if there is any way to install win dvd after uninstalling it.
thanks in advance
Hi marino
hi,
thanks in advance
