hi there the plastic border around the xblack screen is not touching the screen exactly the sides are but the middle part is not , just wondering if it is normal, its like its loose or somthing,
This sounds a little like the problem i have been having, I suppose the best thing would be to log the problem with Vaio Support but unless it is causing any problem with the screen functionality then there shouldn't be a need to get it sent away (unless the gaps are huge.
