hi there,
when i start up my ar21s then press F2 to get into the bios, just before the bios comes a black screen comes and tell you what processor and memory you have, well on my AR21S it says 1 Processors found, i thought theres supposed to be 2 processors, help me out man getting all paranoid here. when i go to system information in windows it shows 2 processors, Y doesn't it show it before the bios loads up
There's one processor, but 2 cores.
It's like the brain, it's one with many chambers
HTH
