Hi there,
In the process of installing the SonicStage, the following error message appeared :
I have no idea what this message means
Would really appreciate if someone could shed some light on this error message.
Many Thanks
Hi Serene
You might want to move this thread into "Sony Software". You're more likely to get a reply there.
Good luck.
Would be cool if masters could move topics, but we can't, so its left to the admins
Ah, Kee-Lo, a matter of semantics! I suppose I meant re-creating the thread under the Sony Software heading.
The error message refers to the Installshield engine. You could try making sure that any previous versions of Sonicstage are uninstalled and that the Sonicstage folder on your drive is deleted before attempting to reinstall. Make sure your system is virus free and that your virus scanner is not running while you install.
Other than that there is probably little you can do other than check for any update on www.vaio-link.com and/or contacting Sony.
Regards, Rob
